[ICEM] boundary layer mesh
Old   October 20, 2015, 00:27
Exclamation boundary layer mesh
Vishnu
CFD_Aspirator is on a distinguished road
Hello all,
I have a 3d cylinder geometry, with the top as inlet, base as wall and sides as pressure outlet boundary conditions. I used a o-grid type of meshing using ICEMCFD. For the sake of boundary layer, the mesh is gradually increased from the wall (using geometric1 option in ICEMCFD). But the problem is the length of a cell immediately next to the wall (base of the cyl) is about 50 times its height. i.e., the aspect ratio is too high. I cannot further decrease the cell length as the total number of cells is very high. I also cannot increase the height of the first cell as that height is required to maintain y+ value < 1. So how can I rectify this problem??
CFD_Aspirator is offline   Reply With Quote
Old   October 22, 2015, 10:46
Sebastian Engel
bluebase will become famous soon enough
Hi Vishnu,
if the flow is parallel to the longest side of an element the high aspect ratio might not be a problem.
You are trying to simulate a flow with a stagnation point? Well... how about squeezing elements to the center, where you need low aspect ratio. Closer to the boundaries the flow should align parallel to your base plate. In this region high aspect ratio elements should have a lower impact on the simulation.
with regards,
Sebastian
bluebase is offline   Reply With Quote
Old   October 22, 2015, 11:11
Vishnu
Hai Sebastian,
There is no stagnation of fluid and the flow is indeed parallel to the base plate. So there shouldnt be a problem as you said.
Thank you.
Old   October 22, 2015, 14:39
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Try wall function since you have so much limitations. I believe they should produce equally sufficient results
shereez234 is offline   Reply With Quote
aspect ratio, boundary layer meshing, icemcfd, o-grid
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Grid Independence of Boundary layer Luigi_ Main CFD Forum 0 December 14, 2011 14:42
