[ANSYS Meshing] Connection Group OR Share Topology ? |
October 7, 2015, 09:16 |
Hello everyone,
My question is pretty simple : Would you use Connections in ANSYS Meshing rather than Share Topology in Design Modeler ? "Why would you do such a thing" you ask ? Here is why : Share Topology creates a multi-body part and, as we all know, multi-body part = 1 CPU meshing. I have ~50M cells mesh and it take around 3~4 hours to create. Wouldn't Connection group allow conform mesh between parts connecting bodies and then perform parallel meshing ? If so, why using share topology ? Regards, John |
October 7, 2015, 10:09 |
Rep Power: 18 |
October 7, 2015, 10:37 |
O_O !
Please enlighten us on that. Everything I've read so far tells otherwise.. :/ |
October 9, 2015, 10:34 |
sluzzer
Rep Power: 12 |
Shared topology is used to create Multibody parts (to create single domain in cfd software with conformal mesh between bodies)
Connection group just indicates there is non conformal mesh (u can use interface model in cfd softwares) |
connection, design modeler, meshing, share topology |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Are my IRIXbs systune parametersb setting correct | lakeat | OpenFOAM Installation | 1 | May 5, 2008 10:48 |
