[ICEM] Meshing a cavity within an aerofoil
Old   October 1, 2015, 06:40
Question Meshing a cavity within an aerofoil
Teja
Alwaysabeginner is on a distinguished road
Hey!
ICEM beginner here. I'm trying to mesh a small cavity (to be used as a jet) on the surface of a NACA0015 aerofoil (Picture attached). I want the cavity region to be ideally filled with an all tri mesh and a structured mesh outside.
I'm using a standard C-grid mesh for the aerofoil.
While I can do both individually(as separate files), I'm not able to mesh the complete geometry. Couple of methods which I tried out were:
1) Mesh the cavity in a separate block, and later convert it into a free block. In this method I can't seem to merge the two meshes at the interface.
2) Mesh only the aerofoil separately and the cavity separately(using the inbuilt unstructured mesh option). Here, the interface still acts as a wall, and hence there is no interaction between the outer field and the cavity.
In another case, I also tried creating two interfaces (as curves) b/w the two parts (vis. external field and cavity) and tried to give them the interface BOCO in Fluent - but that does not work (solution is diverging)
3) I tried using a single block to capture the entire geometry - however, the cavity is not getting captured at all ( I can't seem to "bend" the mesh to capture the details of the cavity.
I'm at a loss on how to proceed now. I hence have two questions:
1) Can a edge associated on a curve have no BOCO explicitly mentioned (i.e. can I make it a part of the fluid flow itself)?
2) What's the best strategy on how to proceed?
Thanks in advance!
Alwaysabeginner is offline   Reply With Quote
Old   October 1, 2015, 12:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can do it in the following way. :
Method 1:
1. From the block inside the airfoil (usually solid), split it three locations : two vertical and one horizontal (at bottom of jet).
2. Associate the vertices to corresponding points and edges to curves. You will also need curve at the airfoil and jet intersection.
3. As the mesh inside the jet will distorted during different events of ejecting and suction, I would recommend using tri mesh inside cavity. You can convert blocking into free mesh, as you have already mentioned.
Method 2:
1. Create the hexa mesh for airfoil as usual.
2. Create tri mesh inside the jet along with prism layers.
3. Merge them in ICEM CFD (see my tutorial on 2d hybrid meshing on forum)
Far is offline   Reply With Quote
Old   October 3, 2015, 13:48
Teja
Nice! Thanks a lot!
I have a follow up question. This curve that you mention at the interface : It still carries over to fluent as a separate entity. What boundary condition should I give on the same (it should ideally not be there). In other words, I want the fluid to interact in both the quad-dominant and tri-dominant parts - the curve is preventing me from doing so (Deleting the curve results in the mesh going awry). Is there a way to link the two "fluid" regions - outside the jet and inside the jet together?
Old   October 3, 2015, 14:07
Far
Sijal
Originally Posted by Alwaysabeginner View Post
Nice! Thanks a lot!
define it interior
Old   October 3, 2015, 16:58
Teja
Thanks a lot for your inputs!
Old   August 13, 2022, 11:59
Default where is the tutorial on 2d hybrid meshing?
alireza
alirez is on a distinguished road
Method 1:
Method 2:
alirez is offline   Reply With Quote
2d cavity, boco, merge mesh
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[GAMBIT] Meshing a spherical cavity over a cylindrical duct avd28 ANSYS Meshing & Geometry 1 July 17, 2015 03:05
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 02:59
digitizing an aerofoil/ meshing problems Simon FLUENT 2 February 27, 2006 12:18
Meshing an aerofoil with a plain flap Fatou FLUENT 0 November 15, 2005 15:24
