[ICEM] Meshing inclined cylinder with PBC tetra mesh ICEM |
September 26, 2015, 18:27 |
shashi
Rep Power: 11 |
I am fairly new to ICEM and CFD in general, I owuld like to mesh an inclined cylinder with periodic boundaries on the top and bottom of the cylinder (infinite cylinder), I tried setting the translation vector (the cylinder length vector from base to top) at the global mesh setup, but i get a mesh which is totally off! here's the .prj file attached. (the cylinder is inclined at 75 degrees to the flow direction, length = 1.5, so axis vec = 1.5cos(75),0,1.5sin(75) the image shows the mesh i generated but it's not periodic. P.S : moderator/admin, could you please delete my post at the Mesh Generation & Pre-Processing Thanks and Regards, shashi |
Meshing inclined cylinder with PBC tetra mesh ICEM | shashi_soman | Mesh Generation & Pre-Processing | 1 | September 26, 2015 18:05 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Hexa + Tetra meshing (Hybrid) in ICEM | vmlxb6 | ANSYS Meshing & Geometry | 12 | December 27, 2010 10:18 |
[ICEM] ansys icem tetra mesh to fluent_v6 conversion problems | milleniumrider | ANSYS Meshing & Geometry | 5 | May 20, 2010 15:55 |
[Commercial meshers] ansys icem tetra mesh to fluent_v6 conversion problems | milleniumrider | OpenFOAM Meshing & Mesh Conversion | 3 | May 13, 2010 14:54 |
