[ICEM] Blocking and meshing of complex hull surfaces |
Daniel Coelho
Rep Power: 14 ![]() |
I have been trying to generate the mesh for a complex boat hull on ICEM, but I get bad elements everytime and my simulation diverges. The shape of the hull is below:
BOAT1.PNG BOAT2.PNG The ICEM files to generate the blocking and Pre-mesh (for the hull without the wave deflector) are below: DOMAIN.zip ICEMCFD.zip I accept suggestions for the blocking stage in order to get elements of good quality. |
bad elements, blocking, hull, icem, low quality |
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator | Crank-Shaft | ANSYS Meshing & Geometry | 5 | January 17, 2016 23:29 |
[ICEM] Meshing complex geometry using hexa with single blocking | piyupant | ANSYS Meshing & Geometry | 0 | July 15, 2015 06:05 |
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp | Crank-Shaft | ANSYS Meshing & Geometry | 0 | January 11, 2013 05:48 |
[ICEM] Meshing a complex pipe network | Industrial_CFD | ANSYS Meshing & Geometry | 0 | January 31, 2012 15:59 |
[ICEM] Hexa meshing blocking problem | fergal | ANSYS Meshing & Geometry | 0 | June 28, 2011 10:01 |
