[ANSYS Meshing] mesh of pipe which inserted a wire coil in this pipe |
View Poll Results: which type of mesh | |||
hex | 4 | 57.14% | |
sweep (but it is failed) | 2 | 28.57% | |
tetra | 1 | 14.29% | |
Voters: 7. You may not vote on this poll |
September 18, 2015, 09:24 |
tuna
Rep Power: 11 |
Hi everyone
I want to do mesh like below figure but I dont know which type of mesh is suitable. I applied the hex dominant mesh sytle but as I did not want. Can you help me ? Best wishes |
September 18, 2015, 09:59 |
Rep Power: 18 |
You may try Multizone method, but I think it is unlikely you can do such mesh in AM.
September 18, 2015, 10:50 |
tuna
Rep Power: 11 |
September 18, 2015, 12:35 |
Rep Power: 18 |
November 5, 2015, 08:33 |
sweep mesh and mapped face error
#5 | |
tuna
Rep Power: 11 |
I used sliced features in DM. I seperate 5 parts. This parts is done with using add frozen features but coil is sliced material. But I can not use sweep mesh, mapped mesh and inflation. Can you help me ? I attached the geometry and I showed the error faces. Thank you |
November 5, 2015, 10:01 |
Mr CFD
Rep Power: 15 |
Mesh the front face and sweep it along the path of the coil.
November 6, 2015, 09:07 |
tuna
Rep Power: 11 |
November 7, 2015, 01:48 |
tuna
Rep Power: 11 |
mesh of pipe |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ICEM] Twisted wire surrounding pipe | geod | ANSYS Meshing & Geometry | 3 | March 10, 2015 12:26 |
[Other] Mesh generation method for coil heated within shell | Asghari_M | ANSYS Meshing & Geometry | 0 | June 8, 2011 08:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] generate a graded pipe mesh. | jenright | OpenFOAM Meshing & Mesh Conversion | 0 | August 22, 2009 08:58 |
