September 11, 2015, 02:51 |
Poor Quality Mesh
Ali
Rep Power: 16 |
How can I make the fine mesh near the wing? Very Poor mesh. Image is attached.
Best Regards Ali |
September 11, 2015, 03:05 |
Stuart
Rep Power: 26 |
You can set global mesh properties with advanced size functions activated, that will help with the curvature and proximity and minimum/maximum mesh sizes. You can also set local mesh sizings to the wing. You will also probably want to apply inflation layers to the wing to capture the boundary layer. Have you done the Meshing tutorials? They cover these topics.
September 11, 2015, 03:14 |
Ali
Rep Power: 16 |
Yes, I did. I applied advanced size functions, on wing meshing is "Mapped" if I further decrease size, mesh size becomes huge and sometimes failed to mesh or taking too long to mesh.
Do you (@SiW) have any particular tutorial related to wing in Ansys Meshing?
Best Regards Ali |
September 11, 2015, 04:22 |
#4 | |
Rep Power: 18 |
September 11, 2015, 06:03 |
Ali
Rep Power: 16 |
Thank you Antanas.
It's 2D. I am working in 3D. Actually it's a helicopter blade placed inside a moving zone. The mesh consists of two fluid zones i.e. stationary and moving zones. The mesh between stationary and moving zone is good but the mesh inside moving zone (around the blade section) is very poor (attached picture in post). I need suggestions to improve the quality.
Best Regards Ali |
September 11, 2015, 07:41 |
Stuart
Rep Power: 26 |
There is a tutorial as part of the Meshing installation and should give you a good start for you to try various features. Open ANSYS Meshing help and it is at: help/wb_msh/msh_tut_asf_meshgeneration.html (see uploaded image).
September 11, 2015, 08:19 |
Ali
Rep Power: 16 |
Thanks SiW,
I will try and report back.. Is there any volume mesh tutorial for an external flow configuration?
Best Regards Ali |
September 11, 2015, 08:55 |
Stuart
Rep Power: 26 |
Use your ANSYS Customer Portal access to download many ANSYS Meshing tutorials and you can also watch the training videos, there you will find a tutorial on automotive external aerodynamics.
ansys meshing, mrfzones |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
