[ICEM] ICEM Meshing Beginner facing problem importing file. |
September 2, 2015, 14:18 |
Rezaur Rahman
Rep Power: 11 |
Dear experts,
I am a very new user for ICEM meshing as I have knowledge of work bench for last 6 month and used the default meshing while doing analysis. I know how to make drawings in ansys workbench. I am trying to learn ICEM CFD and imported the file from the workbench modeler. When I click on the_show curves- on ICEM geometry I found Edges numbers not the curve numbers. I failed to create mesh for beginner for several times. I tried a 3D simple geometry but When I import the file from modeler I am only seeing 2D geometry in it. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
