[ICEM] Problem with prism cells
Old   September 1, 2015, 08:09
Smile Problem with prism cells
Sidharath
sidharath is on a distinguished road
I am modeling compressor stage and using a fairly standard process in ICEM CFD 15.0.
Geometry clean up --> surface mesh using octree-->Delaunay for vol --> mesh inspection and merging/moving nodes as per need --> make consistent and flood fill --> check mesh --> prism layer.
In my earlier models this approach worked just fine. I am doing mesh independence study now and this problem has surfaced. I get below pasted errors and then i can't export the mesh in CFX (gives the error: not able to generate the valid mesh elements).
cells near -0.029893 -0.019099 -0.024232 occupy the same volume
cells 15692 and 44060
face node numbers 2306856 8236784 8615586
opposite vertices 4114464 4114464
cells near -0.038707 -0.022714 0.013155 occupy the same volume
cells 1245012 and 3603
face node numbers 7702011 7702012 8226339
opposite vertices 7702010 1437046
cells near -0.038904 -0.022690 0.013163 occupy the same volume
cells 3603 and 4871369
face node numbers 1437046 7702011 7702012
opposite vertices 8226340 7702010
cells 3603 and 99903
face node numbers 1437046 7702011 8226339
opposite vertices 7702012 8226340
cells 81795 and 3603
face node numbers 1437046 7702012 8226340
opposite vertices 2761432 8226339
face node numbers 1437046 8226339 8226340
opposite vertices 7702011 7702011
cells near -0.029957 -0.018940 -0.024029 occupy the same volume
cells 50299 and 15692
face node numbers 2149332 2306856 4114464
opposite vertices 8615586 8615586
22 more messages - not printed
All messages saved to file ERROR_LOG6.tmp"
Before generating the prims, default check mesh shows no errors (except multiple edges, which are intended in model).
I was wondering if anyone could share inputs on what might be wrong with model.
How can i see these element number mentioned in the error log in ICEM screen and also if i could get any pointers on the direction to mitigate this situation would be highly appreciated.
Thank you and I look forward to response.
sidharath is offline   Reply With Quote
icem cfd 15.0, prism layer
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
[ICEM] ICEM prism layer results in Fluent NULL pointer cells Will Anderson ANSYS Meshing & Geometry 5 February 19, 2011 13:17
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Unresolved & Problem Cells of Solid Type Harry Siemens 1 August 2, 2005 16:11
problem while looping over cells in LES Jimmy FLUENT 0 September 5, 2002 16:33
