[DesignModeler] Imported geometry file with 84 bodies and parts, how to solve it?
Old   August 20, 2015, 08:29
Default Imported geometry file with 84 bodies and parts, how to solve it?
sifet is on a distinguished road
Hello all, I import external geometry file (from Inventor, step. file), but it shows 86 parts and bodies. Is that a problem for the analysis? Do I need to import as a single solid body? Because however hard I try, I can not convert the file into single body file in Ansys
best wishes
sifet is offline   Reply With Quote
Old   August 21, 2015, 16:01
Default Solved
Ok, if you dont want any headache use plug-ins, for example, In Inventor there is ANsys 16 plug-in, I did not use that but instead tried to export some file format and then use it, but it seems that best form is to use plug-ins which is far better than the converting and also less problems
best wishes
design modeler, import geometry, inventor, more than one part
[DesignModeler] Enclosure (cylinder body) around imported geometry executor ANSYS Meshing & Geometry 4 March 29, 2016 13:08
import to Ansys Fluent Design modeler shows 4141 parts and bodies samnath FLUENT 5 April 6, 2015 03:22
[ANSYS Meshing] How to transfer bodies in FE Modeler to Initial Geometry goddy72 ANSYS Meshing & Geometry 2 March 11, 2015 04:18
[DesignModeler] Parts and bodies in DM futureamour ANSYS Meshing & Geometry 2 March 6, 2014 11:04
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
