[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? |
August 19, 2015, 19:12 |
Jackie Stan
Rep Power: 11 |
This is a cohesive heat transfer analysis involve several solid and one fluid region. Initial mesh was generated in workbench mesh. However mesh in the fluid region cause iteration problems. (See https://www.dropbox.com/s/5ga2bnep39tqkmh/1mesh-cross-section.PNG?dl=0)
So I imported mesh generated from workbench mesh into Fluent meshing (Tgrid), Used auto mesh to generate the mesh for the whole part. Mesh in the fluid seems better, But mesh in the solid is bad (See https://www.dropbox.com/s/r52q0u7iwpinv48/4.png?dl=0) Can I keep the sweep mesh in the solid and only remesh the fluid region in Tgrid? Or is there a way to generate sweep solid mesh in Tgrid? The solid parts and fluid share the same interface (identical surface mesh) for the purpose of cohesive heat transfer analysis. Thanks for helping! |
August 19, 2015, 19:17 |
How to generate good mesh for Fluent cohesive heat transfer analysis
Jackie Stan
Rep Power: 11 |
Advice on how to generate good mesh involve several solid body (rectangular shape solid except heat sink) and a fluid region for cohesive heat transfer analysis is greatly appreciated!
meshing combine, tgrid, workbench mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[ANSYS Meshing] Solid inside Fluid - Multizone meshing | supercolli | ANSYS Meshing & Geometry | 2 | July 9, 2014 14:20 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
