[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit
Old   August 17, 2015, 21:31
Default Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit
Jackie Stan
RPjack is on a distinguished road
Learned a lot from the forum. Hope my first thread will help me solve the problem.
Fluent Conjugate heat transfer analysis. Temperature at a small fluid region is extremely high.
It is power module forced liquid cooling analysis, heat generated at the die, conducted through several layers of solid, then dissipate via pin fin heat sink to the fluid. Mass flow inlet and pressure outlet. Coolant temperature 300K. Temperature in a small region near heatsink fins (see image) diverged after ~100 iterations.
Temperature at most liquid region is reasonable(~300K). However temperature of a small portion of liquid is over 3000K(https://www.dropbox.com/s/0eqjt4me2q...htemp.png?dl=0), where temperature of a nearby small region is only ~57K. (https://www.dropbox.com/s/bvny7gadmm...wtemp.PNG?dl=0)
During iteration, at first, “Reversed flow in xx faces on pressure-outlet” appeared after ~100 interactions. After another 20 iterations, message “ temperature limited to 1.000000e+00 in 6 cells on zone 18 in domain 1, temperature limited to 5.000000e+03 in 1 cells on zone 18 in domain 1” appeared. See regions with extreme high and low temperature
Thanks to old forum discussion(http://www.cfd-online.com/Forums/flu...879-cells.html) , I think mesh is the problem. Here, ANSYS mesh is used (see https://www.dropbox.com/s/5ga2bnep39...ction.PNG?dl=0)
1. Sweep mesh at the most solid
2. Prism mesh defined at fluid/solid interface
Any suggestion how to improve mesh is greatly appreciated!!!
Tried to use ANSYS meshing (Tgrid), Generate Prisms mesh successfully, but could not mesh the rest fluid region with tetra mesh, the error message “Non-triangular surface mesh”
Thanks in advance!
RPjack is offline   Reply With Quote
Old   June 20, 2019, 08:11
Mayank
May19 is on a distinguished road
dear sir,
I am simulating a pipe flow with polynomial function of temperature of all properties for Re 30000 and inner and outer diameter of pipe 0.02 & 0.025 m me too is suffering with same issue in starting 20 iteration it shows reverse flow in xxx cells at outlet and after that Temp limited to 5000 & 1000 K in my fluid and solid domain respectively also after that Cp value reported to be negative and AMG solver gets diverge....
Please if you find the solution of the same then please help me out...
Thanks in advance.
May19 is offline   Reply With Quote
conjugate heat transfer, exceed temperature limit, fluent, mesh
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
conjugate heat transfer case from two meshes skuznet OpenFOAM Pre-Processing 0 July 1, 2014 18:09
Radiation interface hinca CFX 15 January 26, 2014 18:11
conjugate heat transfer - temperature at coupled patches maHein OpenFOAM Running, Solving & CFD 1 September 6, 2012 07:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
