[ICEM] Create coincident surfaces
Old   August 4, 2015, 08:50
Question Create coincident surfaces
David J.
jFoam is on a distinguished road
Hello CFD-Community,
I am currently working on an ICEM script that creates a geometry of a lubricating gap of a bearing by bottom-up-method.
I noticed that when I create cylindrical surfaces by curves (two circles), the boundaries of these surfaces do not exactly match the curves they're based on. This is espacially problematic when, in the later process, I want to intersect two surfaces and there is a clearance between the generated intersection points and the original curves.
So what I am looking for is an ICEM scripting command that forces ICEM to create surfaces that are coincident with the original curves.
Thanks in advance,
David J.
jFoam is offline   Reply With Quote
coincident, curves, icem, surface
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
[swiftBlock/swiftSnap] How do you create your 2D geometries in Blender? sur4j OpenFOAM Community Contributions 2 January 4, 2014 17:31
create patches out of a patch with two parallel surfaces Rebecca513 OpenFOAM 6 March 15, 2013 17:14
Create Multiple Surfaces shashank312 FLUENT 0 December 13, 2011 16:30
Surfaces Mark FLUENT 2 February 9, 2004 11:41
