[ANSYS Meshing] Meshing a cavity in an airfoil |
July 27, 2015, 16:14 |
Karim
Rep Power: 11 |
Hello everybody,
I'm trying to mesh an airfoil with a small cavity in it, but there is a problem with the o-grid mesh over the cavity (it messes up the distribution of the cells so that no matter how many cells I specify along the airfoil surface, I can only get one cell over the cavity, see 1st photo). I'm sure that this is because of the gap in the airfoil because I have never had this problem before. I'm not sure if it's a blocking problem, or associations problem or something different. mesh.jpg blocks.jpg Would really appreciate it if you could give me some advice with it for my Masters Thesis. Many thanks, Karim |
July 27, 2015, 19:44 |
Rep Power: 13 |
Isnt this an ICEM problem? Change the description so ICEM users will go through this. It currently says ansys meshing...
July 30, 2015, 08:21 |
Karim
Rep Power: 11 |
Hi hwet, thanks for your reply. It is an ICEM problem, but I couldn't find a sub forum dedicated to ICEM. I thought that ICEM problems are under ANSYS.
[ANSYS Meshing] Meshing a cavity in an airfoil | kashawki | ANSYS Meshing & Geometry | 0 | July 23, 2015 15:20 |
[GAMBIT] Meshing a spherical cavity over a cylindrical duct | avd28 | ANSYS Meshing & Geometry | 1 | July 17, 2015 03:05 |
[ANSYS Meshing] Meshing 3 Element Airfoil | mr.rushikumar | ANSYS Meshing & Geometry | 0 | March 1, 2014 23:57 |
dynamic meshing for 2D airfoil | JochemGrietens | Mesh Generation & Pre-Processing | 4 | December 10, 2013 14:13 |
[GAMBIT] Problematic meshing of an inverted airfoil | snkutta | ANSYS Meshing & Geometry | 2 | October 11, 2011 14:23 |
