[ANSYS Meshing] How to increase meshing speed? |
July 22, 2015, 16:38 |
I am currently using Ansys meshing to generate the grid for my model. Unfortunately it is working really slow... I use Ansys 15.0, my computer is 16GB RAM and i7, 4 cores, However Ansys permanently uses only around 7GB memory and 20% of the CPU... Geometry is quite complicated and usual number of cells is around 6-7 mln. However the process of meshing is taking around 3-4 hours! I also got Ansys 16 on the virtual machine with 64GB of RAM, but meshing is exactly as slow as on my computer. Could you help me somehow? How I can increase meshing speed? Why the software doesn't use full capacity of the computer? Thanks |
July 22, 2015, 19:42 |
Rep Power: 14 |
HI Sylwia,
Meshing uses 1 core to mesh so it will be same speed in any computer. If you have multiple license available then depending upon size of mesh , meshing utilizes other license to make it faster. The only way to make it faster is by having more than 1 license. Cheers KAPI |
July 23, 2015, 03:51 |
Stuart
Rep Power: 26 |
Maybe this section of the Meshing User Guide will help: Meshing User's Guide / Global Mesh Controls / Advanced Group / Number of CPUs for Parallel Part Meshing.
July 23, 2015, 10:02 |
I already tried already to change the number of CPU in Ansys Options, but it didn't change the meshing speed. So I guess I have only one licence...
Thank you! |
ansys |
Meshing software comparison | Wikie | Mesh Generation & Pre-Processing | 5 | September 29, 2014 07:09 |
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? | pipolaki | ANSYS | 0 | December 6, 2013 09:12 |
Hard disk speed important to increase CFD computing speed? | lawrencelaw | Hardware | 13 | November 17, 2009 15:35 |
Does it metter to increase RAM for solver speed?? | raima | Main CFD Forum | 1 | February 28, 2008 11:47 |
How to Increase Speed? | steve podleski | Main CFD Forum | 23 | January 11, 2000 16:41 |
