[ANSYS Meshing] Iterative multizone meshing
Old   July 20, 2015, 19:34
Default Iterative multizone meshing
Krishna Sandeep
Krishna Sandeep is on a distinguished road
Hi all,
I am using ansys meshing to mesh a complicated geometry. I am attaching a picture of a portion of the geometry that I have to mesh. I want a hexahedral mesh in this region and I know that it is possible to get it using multizone method. The issue is that the process of meshing should be iterative. The grey region on the left is a rectangular slot with a circular inlet. The other grey one, blue and orange are parts of cylinders and can be meshed with hexahedral elements. The thin plate like things are fluid gaps to which I prescribed a sizing in the z-direction. Can anyone guide me as to how to mesh this whole unit as a multizone?
Krishna Sandeep is offline   Reply With Quote
Old   July 20, 2015, 20:11
hwet is on a distinguished road
you will have to do this in parts, you cant apply multizone to the whole geometry. If you really want an easy way to hex mesh this try cutcell meshing.
hwet is offline   Reply With Quote
Old   July 20, 2015, 20:49
Krishna Sandeep
Hello thank you for replying quickly. Can you please elaborate on how to use cut cell meshing for this geometry?
Thanks.
Old   July 20, 2015, 20:55
You will find the option in the meshing details tree, or i will suggest look it up on ansys meshing tutorials.
ansys meshing, iterative update, multi zone
[ANSYS Meshing] Pipe bend meshing using MultiZone flotus1 ANSYS Meshing & Geometry 12 August 22, 2015 05:45
[ICEM] Strategies to use multizone for meshing swirl stabilized nozzle rigi ANSYS Meshing & Geometry 0 March 9, 2015 21:24
[ANSYS Meshing] Solid inside Fluid - Multizone meshing supercolli ANSYS Meshing & Geometry 2 July 9, 2014 14:20
[ICEM] Multizone meshing Problem for External Flow Meshing Hybrid ANSYS Meshing & Geometry 9 March 29, 2013 10:24
[ANSYS Meshing] multizone meshing firatwsen ANSYS Meshing & Geometry 0 December 15, 2011 15:32
