[ICEM] Too cambered airfoil
Old   July 18, 2015, 18:23
Default Too cambered airfoil
Massachusetts
kayla1994 is on a distinguished road
Hello to all,
i have some problem meshing NACA 6606 airfoil, because it's too cambered.
Starting from picture 1 i associated the edge to the airfoil and i obtained the situation in picture 2.
With low cambered airfoil the green lines goes into the airfoil but with this airfoil they remain external.
Then i usually mesh and i eliminate the internal part of the mesh using the command "eliminate block".
The problem is i don't know how to import the green line into the airfoil and eliminate the block to obtain only an external mesh
Thanks for help
kayla1994 is offline   Reply With Quote
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
[ICEM] Importing cambered airfoil geometry to ICEM CFD kotimari ANSYS Meshing & Geometry 2 July 16, 2012 16:44
