[Workbench] Run ICEM Script in Workbench Script
Old   July 17, 2015, 13:09
Default Run ICEM Script in Workbench Script
Michelangelo
MIZOR is on a distinguished road
Hi User,
What's the command script in Workbench Scripting to run a ICEM journal?
Because I'm doing a optimization in WB and I have to control all program with a WB script. I use DesignModeler to generate geometry and then I'll pass the information to ICEM and I generate mesh with a ICEM script.
But I don't know run ICEM script in WB script, for DesignModeler the command is RunScript(file path) but for ICEM I don't know.
Thank you
MIZOR
MIZOR is offline   Reply With Quote
Old   October 4, 2016, 12:18
Johannes Hall
yonpanman is on a distinguished road
I'm having the same problem, been trying to look for a way to run an ICEM script or journal from Workbench but I can't seem to find how to do it. Did you have any luck?
Regards
yonpanman is offline   Reply With Quote
Old   October 6, 2016, 17:42
Michelangelo
try with follow command:
icempath = "yourdirectory/icemscript.rpl"
script = open (icempath, "r")
array = [ ]
for line in script :
array.append (line)
script.close ( )
Version 14.5 Ansys Workbench
Old   October 7, 2016, 03:16
Johannes Hall
Thank you Mizor, I will try it out
Regards
Old   June 22, 2017, 14:20
Levente Lázár
LLevente is on a distinguished road
Hi guys,
I have an ICEM script, that works well, if I open the ICEM, but I would like to run this script in workbench.
I tried this workbench journal, what Mizor wrote, and I didn't get any error message, so it can run , but it didn't make the meshing.
# encoding: utf-8
# Release 17.0
SetScriptVersion(Version="17.0.323")
icempath = "mypath/ICM.rpl"
array = [ ]
	array.append (line)
script.close ( )
What else should I write?
Thanks
Levente
LLevente is offline   Reply With Quote
Old   June 22, 2017, 19:49
Michelangelo
I levente,
your script work well in ICEM?
You can try use only ICEM to test script.
Old   June 23, 2017, 04:52
Levente Lázár
Hi Mizor,
thanks for the quick answer!
The Icem script works perfect, if I run it in Icem.
Also, if I update the project in workbench (and the mesh is not ready).
By the way, the Icem script begins with Close Mesh.
It could be good too maybe, if the Workbench script opens the Icem, and automatically runs the Icem script.
The aim is, that I dont have to click on icem and wait until he opens, and after that click on the "Run script". Just: I am in Workbench, then press Enter (or click on sg) and until the simulation works everything.
Thanks
Old   April 1, 2018, 11:59
Mengjie Zhao
Mengjie is on a distinguished road
Hi LLevente,
I'm currently facing the same problem as you do, did you find a solution to solve this?
Mengjie is offline   Reply With Quote
Old   April 4, 2018, 03:56
Levente Lázár
I can not find it.
Old   April 4, 2018, 08:45
CT
cturutoglu is on a distinguished road
If there's a replay named after the ICEM project directory inside the directory itself, workbench will automatically run the replay file when you update.
So if there's an ICM-1.rpl inside Workbench_files/dp0/ICM-1 folder, ICEM should automatically use that replay when you update from workbench. You don't need to put special commands in wbpj file . . . at least that's how I do it.
cturutoglu is offline   Reply With Quote
[ICEM] launch ICEM replay file from wb script cillo273 ANSYS Meshing & Geometry 1 July 19, 2015 03:47
[ICEM] Remeshing script using ICEM CFD replay mateusdias89 ANSYS Meshing & Geometry 2 February 15, 2015 15:18
[ICEM] ICEM CFD script CFD-1987 ANSYS Meshing & Geometry 3 June 5, 2012 08:56
[ANSYS Meshing] Problem with Icem Script Krish ANSYS Meshing & Geometry 0 October 18, 2011 13:10
ICEM CFD in Workbench marek CFX 1 February 15, 2008 11:35
