[ANSYS Meshing] Remove faces from defined selection
Old   July 3, 2015, 11:54
Default Remove faces from defined selection
mariam.sara is on a distinguished road
Hello the image attached represent a finned tube part with hiding the water and air regions. My question I need to remove two faces from the interface boundary using the option (Remove from current selection) but I think it not work properly when I press over the faces it seems the boundary still the same without removing the faces I select? what the problem?
Thanks
mariam
mariam.sara is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
