[DesignModeler] Smaller surface body from face |
June 26, 2015, 16:48 |
NC
Rep Power: 11 |
I need to make a surface body from a curved face for use as a body of influence in Meshing (while keeping the original face as a boundary). What's the most efficient way to do this?
Here's what I did: 1. Define a point by coordinate to be the center of my surface. 2. Make a plane centered at that point. 3. Sketch an ellipse. 4. Extrude w/ the imprint option to the curved face. But this isn't working (no imprints are created). This doesn't seem like the right way to go about it. Can anyone point me in the right direction? Thanks. |
June 29, 2015, 03:28 |
Imprint faces won't work if the body is "Frozen". Maybe that is your issue.
surface body |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
