[ANSYS Meshing] Results getting worse with Refinement
Old   June 20, 2015, 15:04
Default Results getting worse with Refinement
Tiago Fonseca Costa
TiagoFC is on a distinguished road
I'm simulating a drag on a sphere with Re = 10.000. In the internet, my references for a acceptable value for it's drag coefficient are from 0.39 to 0.47. I tried a simulation with a 1m radius sphere on a 20m uniform box enclosure. I'm using SST as a turbulence model and I'm getting pretty good results without any kind of Mesh Refinement (the Drag Coeff. calculated was 0.484, pretty close to the acceptable values). But when I add Refinement to the surface of my sphere (on the fluid side), all the three types of it (Refinement level 1, 2 and 3), my results just go to something like 0.19, 0.20 (and I expected them to go to a range of 0.40, 0.45 or something inside the acceptable range). Does anyone have an idea of what's going on?
Tiago.
(P.S.: sorry for bad English, not my native language!)
TiagoFC is offline   Reply With Quote
Old   June 23, 2015, 22:44
hwet is on a distinguished road
Do you have an inflation layer?
hwet is offline   Reply With Quote
drag coefficient, refinement, results, sphere
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] SnappyHexMesh not enough refinement simplefoam OpenFOAM Meshing & Mesh Conversion 2 August 30, 2013 04:37
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) Irish09 OpenFOAM Meshing & Mesh Conversion 23 July 15, 2013 08:45
[CAD formats] how to call my .stl file in the terminal izna OpenFOAM Meshing & Mesh Conversion 21 July 9, 2013 17:17
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
