June 16, 2015, 21:35 |
Problem named face cylinder with hole
matias
Rep Power: 11 |
Hello
I just starting with ICEM so i dont know so much I am trying a uniform mesh of a cylinder (D = 200mm) with a hole (D = 1mm) of 5mm of deep I saw tutorials that I found and I did it but I have a problem, when I export mesh to fluent, I canīt see "named face" to set boundary condition. I have read that only mesh generated on the geometrical surface could be recognized as the specified name so I got back to see the mesh, and I saw that "inlet face" wasn't meshed, but i dont know what I am doing wrong I have tried meshing but I don't get it, I only followed steps of the tutorial, so I dont know what to do also the face "wall3" get a oddish mesh this is it I did https://youtu.be/_gR0htoEylc can you help me please? Thanks in advance |
June 17, 2015, 14:29 |
matias
Rep Power: 11 |
Thanks for your attention
I fixed the problem, I only had to delete the block in the hole |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 37 | November 29, 2024 11:15 |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 05:28 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 19:47 |
