June 6, 2015, 23:40 |
Logical cells and vertices
Hyowon Lee
Rep Power: 13 |
Hello, ICEM experts
I have serious problem. I need to understand logical cells and vertices.. I added a presentation file and in the file, you can check the pictures of a cylinder with different numbers of cells. Could you explain why they have different logical cells and why they have odd numbers of logical cells? https://www.dropbox.com/sh/izwmdsqvd...wsQ37k63a?dl=0 Thank you. Sincerely, A novice! |
[mesh manipulation] how should we remove the Concave cells from the mesh? | s.m | OpenFOAM Meshing & Mesh Conversion | 20 | March 5, 2020 17:35 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[blockMesh] "hex" blocks that give prism and tet wedge cells | MaryBau | OpenFOAM Meshing & Mesh Conversion | 1 | January 30, 2013 14:46 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
