[DesignModeler] Error with FLowPath for centrifugal compressor |
Sidharath
Rep Power: 11 ![]() |
Greetings. I am trying to model rotating part/mesh of centrifugal compressor in Turbogrid. In the process of doing this, I am stuck in FlowPath - design modeler. The "Number of Layers" option in the details of FlowPath is frozen to 0 for me and i am not able to edit/change it. If I go ahead and generate the FlowPath (with 0 layers), i am getting this error "Error: Failed to generate because of invalid property/properties Context: ansFClientBMBladeDesign::Execute FlowPath1" What I have done: 1.- Oriented geometry with compressor inlet along +Z direction, 0 at exducer hub. (Please see the picture) 2.- Sliced the geometry with ZX plane and taken the projections of the hub, shroud, inlet and outlet on different sketches. (Please see the picture) 3.- Trying to generate the FlowPath but facing above mentioned problem. Any insights/inputs on what could be going wrong and what can i do to solve this problem would be highly appreciated. Thank you. ![]() |
centrifugal compressor, design modeller, flowpath |
Possible to simulate a working Centrifugal Compressor for jet engine on OpenFOAM? | fazlur | OpenFOAM | 1 | August 21, 2013 04:30 |
Turbocharger Compressor Wheel CFD Analysis | aymen_a22 | ANSYS | 1 | April 20, 2013 10:39 |
[TurboGrid] Turbocharger Compressor Wheel Meshing | aymen_a22 | ANSYS Meshing & Geometry | 0 | March 20, 2013 10:27 |
Centrifugal compressor mass flow error | Attesz | CFX | 18 | May 27, 2012 10:17 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 22:43 |
