[ANSYS Meshing] ANSYS Meshing
Old   May 31, 2015, 04:07
Default ANSYS Meshing
Shane
sircorp is on a distinguished road
Dear All
I have a geometry which has a tiny inlet. The diameter of inlet is just 1 mm. When I do meshing it show a rectangular there. I want to setup meshing for the tiny hole separately not for whole body. Sadly inlet is part of the geometry.
In second case I have another tiny hole of 1 mm inlet but this time geometry is independent.
Geometry for multiple fluid.
I cant put a fine meshing on whole geometry else cells become too many and after few hours of meshing system crashes.
Any one with a suggestion. ( I cant slice geometry as it is not symmetrical)
Thanks for reading this. Any help will he highly appreciated.
Shane
sircorp is offline   Reply With Quote
Old   May 31, 2015, 20:41
Kapi is on a distinguished road
Hi Shane,
Good day!
Can I suggest you to attach your geometry here showing your inlet and the error you are getting?
Cheers
KAPI
Kapi is offline   Reply With Quote
ansys fluent meshing
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 09:12
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 10:48
[ANSYS Meshing] ANSYS Meshing vs. ICEM oborona ANSYS Meshing & Geometry 2 April 19, 2012 12:28
