[GAMBIT] Skewed meshes in meshing of hydrocyclone
Old   May 29, 2015, 07:01
Default Skewed meshes in meshing of hydrocyclone
Iman Sengupta
Iman Sengupta is on a distinguished road
I have problems associated with meshing of a hydrocyclone. I created the geometry and did meshing in Gambit. I used tetrahedral meshes. I have some skew meshes, having aspect ratio more than 0.9. This skewed meshes are causing trouble during convergence. I tried smoothing of meshes in Gambit but unfortunately number of skewed meshes increased from 3 to 26 for both L-W Laplacian and Equipotential methods of smoothing.
Please help me to solve the problem.
Iman Sengupta is offline   Reply With Quote
Old   May 29, 2015, 07:08
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a picture of your geometry
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 3, 2015, 07:39
Iman Sengupta
There are three skewed meshes at the junction of inlet and cylindrical part of the body of a hydrocyclone. I cannot remove these skewed meshes. This meshes are causing problem with convergence.
Old   June 3, 2015, 07:55
-mAx-'s Avatar
Maxime Perelli
check here:
http://www.cfd-online.com/Forums/ans...nlet-mesh.html
Old   June 3, 2015, 08:14
Iman Sengupta
I want to inject feed tangentially to the hydrocyclone. If I change the geometry in the way you are mentioning would I be still able to inject feed tangentially?It may hamper fluid flow pattern inside. Can I do some modification on the meshing?
Old   June 3, 2015, 08:25
-mAx-'s Avatar
Maxime Perelli
sweep the face in x-direction, but with a small vector, just for preventing the sharp edge.
Then you will have a small edge, but you will fix the issue with a size function
Old   June 3, 2015, 08:40
Iman Sengupta
I already followed the steps and found that inlet geometry is little bit modified but did not apply size functions. I took small vectors keeping so that flow pattern should not be severely disturbed. Then I did the meshing with slightly changed geometry. Now the meshing is perfect and there are no skewed meshes.I will run the simulations to check if the results are okay with it.
Old   June 3, 2015, 08:57
-mAx-'s Avatar
Maxime Perelli
you can also split the surface you want to sweep, and then you sweep just the surface next to your sharp angle.
Doing that you will keep your inlet
[ANSYS Meshing] How to get rid of skewed elements while meshing a pipe with many interfacing surfaces everdimension ANSYS Meshing & Geometry 12 September 15, 2016 19:54
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
highly skewed elemnts in Gambit rk2011 Main CFD Forum 1 January 26, 2011 19:24
Urgent help, help pl for meshing problem Shashi FLUENT 8 October 8, 2008 12:24
