[ANSYS Meshing] Avoid STAIRSTEP Mesh?
Old   May 25, 2015, 11:37
Unhappy Avoid STAIRSTEP Mesh?
Luckas Rossato
luckasrossato is on a distinguished road
Hello everyone,
I am working with conecttion between fluid and solid domain, and when I create the mesh it appears some stairstep mesh right at the conections, this way I can't use some models, DTRM model, for example.
Does anyone know how to avoid this problem setting some different parameters on meshing??
Thanks in advance!
luckasrossato is offline   Reply With Quote
Old   May 25, 2015, 21:06
Kapi is on a distinguished road
Hi Luckas,
try to change setting "Maximum Angle" to 180 in Mesh.
Cheers
KAPI
Kapi is offline   Reply With Quote
fluent, mesh, meshing, stairstep
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
