[DesignModeler] Creating multiple solid/fluid volumes. |
May 14, 2015, 16:40 |
nm
Rep Power: 13 |
Okay, I have asked the same question a month back. Didn't help much. I am here again, this time with a sketch.
This attachment Untitled.jpg is a very simplified version of the geometry I want to build. This is the cross section. The actual geometry would be a cylindrical shell with a fluid inside with two solid plates inside. The question is : what is the simplest approach to building this. Is there a simpler way than creating three sketches, extruding them with added frozen in between and subtracting the volumes? Asking this because this process can be tedious and time consuming for the actual geometry. Is there a simpler way? If so please help. Thanks. |
May 14, 2015, 20:02 |
#2 | |
Rep Power: 14 |
Hi nvarma,
KAPI |
ansys 13 work bench, design modeler, geometry generation |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] snappyHexMesh multiple volumes | twinturbotom | OpenFOAM Meshing & Mesh Conversion | 4 | September 9, 2015 09:42 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
[GAMBIT] Creating Separate Mesh for touching volumes | damute | ANSYS Meshing & Geometry | 9 | February 25, 2012 15:32 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
