[GAMBIT] Problems with surface vectors orientation when generating mesh with GAMBIT
Old   April 27, 2015, 10:57
Default Problems with surface vectors orientation when generating mesh with GAMBIT
Solal
solalito is on a distinguished road
Hi all,
I just started my PhD and I am using a code passed down by an old post-doc from my research group. To launch a simulation, I have to generate the geometry and mesh in gambit before importing it into my solver. The solver uses immersed boundary methods (IBM). The code determines if a region of the domain is fluid or solid based on the "Grid K unit normal" vectors (as referred from tecplot).
The code can only switch the direction of ALL the vectors at once. Therefore, if all the vectors are pointing in the wrong direction, then the code can fix that. However, if one of the vectors is wrong then we have a problem.
When generating the mesh in GAMBIT, I cannot seem to control the default direction at which the Grid K unit vectors are pointed to. I emailed my postdoc, he told me there was a way to do it in the older versions of GAMBIT but he doesn't know how in the new version.
Thanks for the help
solalito is offline   Reply With Quote
gambit
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
