[ANSYS Meshing] how to apply interior boundary condition in double pipe heat exchanger
Old   April 9, 2015, 02:23
Default how to apply interior boundary condition in double pipe heat exchanger
manish sharma
m7566 is on a distinguished road
anyone plese tell me how i proceed further
1. how to use interior boundary condition in this model this is a double pipe heat exchanger and also how we use interface boundary condition in this model
2 why this error is occured in mymodel after meshing
m7566 is offline   Reply With Quote
Old   April 9, 2015, 02:45
hwet is on a distinguished road
What error? I dont see any error in the pictures you attached, also could you specify what you mean by interior boundary condition?
hwet is offline   Reply With Quote
Old   April 9, 2015, 03:11
Default the mesh file exporter
manish sharma
the mesh file exporter does not support overlapping geometry in named selection
Old   April 9, 2015, 03:12
manish sharma
Originally Posted by m7566 View Post
Attachment 38480
sir i also want to know how interior boundary condition is applied in my model
Old   April 9, 2015, 03:18
manish sharma
sir i want to impose these boundary condition in my model in image i'm able to understand how interface boundary condition is applied but i'm not able to understant how interior boundary condition is applid in my model this is double pipe heat exchanger
Old   April 9, 2015, 03:37
Very simple: There are faces which have been named twice or more. For example if you name a face as inlet you cannot have another name for the face as well. I often make this error in hurry, it is not a big issue.
Not ever sure what you are trying to ask. If you have made named selection to the faces you want to apply the boundary conditions to, they should be available in the boundary conditions tab in Fluent. Are you trying to make boundaries along the pipe geometry or normal to it inside the pipe? You can make new faces where you want to apply the boundary condition by slicing the geometry and applying the boundary condition to the sliced face. Dont forget, this will create additional bodies you need to select them all and form one part from them to get a conformal mesh...
Old   April 9, 2015, 03:39
Kapi is on a distinguished road
Check your named selection. You mite have named selected same body/face/edge twice.
Also Right click mesh and see overlapping geometry if there is!
Hope it helps.
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   April 10, 2015, 09:21
Paritosh Vasava
vasava will become famous soon enough
If you right-click on the boundary names you should be able to see an option for looking at duplicate entries for boundaries.
vasava is offline   Reply With Quote
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
Double pipe exchanger davidrlc89 CFX 0 December 9, 2012 14:46
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 11:14
Boundary Condition Heat Exchanger counter-corrent mb89 FLUENT 0 March 10, 2012 13:14
How to apply heat flux condition L. Zhu FLUENT 2 January 8, 2003 11:16
