[DesignModeler] Extrude in the radial direction
Old   April 6, 2015, 15:41
Default Extrude in the radial direction
NC
bongbang is on a distinguished road
How can I extrude radially (i.e. in the normal direction) off a face on a cylinder wall? Leaving the direction as "Normal" doesn't work. If I simply select a 3D edge as the direction vector, that doesn't work (result pictured below) because the vector is not really normal to the entire surface.
bongbang is offline   Reply With Quote
Old   September 12, 2018, 17:56
Ali Shayegh
amuzeshi is on a distinguished road
well; copy the following as extrudeMeshDict and place it in /system folder.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      extrudeMeshDict;
sourceCase ".";
constructFrom mesh;
sourcePatches (wall);
extrudeModel        linearNormal;
nLayers             20;
expansionRatio      1.0;
linearNormalCoeffs { thickness  .01;}
mergeFaces false;   // true;
mergeTol 0;
Then run:
extrudeMesh
That's it !
amuzeshi is offline   Reply With Quote
extrude faces
Direction of Rotation of Radial Turbine ghoshi1983 CFX 8 June 19, 2012 11:16
Design Modeler Direction Reference (extrude) natantyt ANSYS Meshing & Geometry 0 June 22, 2011 12:17
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 05:51
Radial Direction contours Felix CFX 0 September 24, 2007 10:15
2D cylindrical problem in axial & radial direction Manoj FLUENT 2 January 5, 2004 13:10
