[ANSYS Meshing] Meshing Detail for Ahmed Body Simulation
Old   March 27, 2015, 17:54
Default Meshing Detail for Ahmed Body Simulation
Steven Goddard
spggodd is on a distinguished road
I am trying to simulate the flow over the ahmed body and compare the CFD results to experimental data.
I have followed Scipy's excellent tutorial on this scenario but I am now trying to refine my mesh further as I'm not sure the inflation parameters defined in the video are sufficient.
https://www.youtube.com/watch?v=dZR7Wi70Vec
To find the first cell height I have done some calculations based on boundary layer flow over a flat plate but using 0.7428m as my length based on the top horizontal surface of the ahmed body. However in order to fit 20 cells (as recomended) into the 10%XL boundary layer (1.2 Stretch factor) the first cell height is 4.65E-6m which seems incredibly small and my PC is struggling with the fine mesh requirements.
Should this kind of size be expected?
Also, I have took this value and calculated y+ based on a formula provided by Ansys:
y+=(\Deltay)/(L\times\sqrt{74}\times Re^{L}_{13/14})
This gives me a y+ of around 1.4 which seems very low for k-Epsilon, literature I've read suggests y+=30 to 200.
Therefore would it be suitable to reduce the 20 cell requirement in the boundary layer calcs in order to reduce the mesh size and improve performance?
edit: I have included my calculation spreadsheet for reference.
Many Thanks
Steve
spggodd is offline   Reply With Quote
Old   March 28, 2015, 09:21
hwet is on a distinguished road
Y+ is actually a measure of the first layer height, if ur y+ is 1.4 it means u can increase the first layer height so the Y+ is upto 30 atleast, 1.4 is wayyy to fine to apply wall functions
read this best explanation ever http://www.computationalfluiddynamic...oundary-layer/
hwet is offline   Reply With Quote
Old   March 28, 2015, 10:38
Steven Goddard
Thanks Hwet, I will have a read through you link now. What I've read so far sounds very useful.
Is it normal practice to calculate the inflation parameters for each edge? For the ahmed body I will have the bottom edge, top edge and the slant. Or is it better to apply the same inflation properties all over?
Do you also need to calculate inflation properties for the non-slip road in the ahmed model? If so what would you use as your characteristic length (L)? (total domain length, body length etc..)
Old   March 28, 2015, 19:35
Depends on your flow over the different regions, it shouldnt make a very big difference anyways having it the same over the different surfaces, I have only a vague idea of what an ahmed body looks like, it all depends on ur flow physics, just mesh it using the guide i posted earlier, and simulate the flow, if you then think the mesh needs to be refined go back to meshing and do that, it is somewhat a trial and error approach
ahmed, body, inflation, mesh
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 9, 2016 00:10
Error in rigid body simulation scarebyte ANSYS 0 June 2, 2013 13:06
[ICEM] Meshing one body part only serezhkin ANSYS Meshing & Geometry 3 June 29, 2010 16:36
Flow around the ahmed body (large eddy simulation) Benzamia CFX 0 February 26, 2007 06:03
Human Body Simulation - Numeric Thermal Manikin Andy Robertson Main CFD Forum 1 March 19, 2001 11:23
