[DesignModeler] Trouble with extrusion
Old   March 18, 2015, 13:02
Default Trouble with extrusion
NC
bongbang is on a distinguished road
This should be really simple, but when I try to exclude my sketch of a circular sector, only the center is extruded as you can see from the preview below.
When I change the geometry to a test triangular I made right next to it, the extrusion is carried out as expected. What's going on? Thank you.
bongbang is offline   Reply With Quote
Old   March 18, 2015, 14:07
Anonymous
marauder is on a distinguished road
What is the error it is showing on extrusion? You can check it by right cliclking on the extrusion tree and select show error. May be it's open geometry...
marauder is offline   Reply With Quote
Old   March 18, 2015, 14:26
NC
There's actually no error. But I deleted everything in the sketch and started from scratch and it now works. Thanks.
extrusion
[mesh manipulation] extrudeMesh: Wedge extrusion with positive AND negative angle francois OpenFOAM Meshing & Mesh Conversion 3 October 20, 2013 05:37
Divergence / Convergence for different inlet extrusion lengths Janshi STAR-CCM+ 8 October 27, 2011 11:32
Difficult ICEMCFD question: Extrusion Walter CFX 11 April 19, 2011 03:22
Creating Extrusion layer in ProAm w/ small geomtry Alicia Siemens 2 September 1, 2005 13:32
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 20:08
