[DesignModeler] Modelling mixing tank using MRF approach
Old   March 17, 2015, 07:26
Default Modelling mixing tank using MRF approach
Nataliia Tatyanko
Natali is on a distinguished road
Hi all. Please help me.
I need to get velocity field around mixer in a mixing tank. The goal is to determine dead zones. So, I import geometry of mixer with outside cylinder in DM. Than I use "enclosure" tool to create tank zone. After substracting ("cylinder" minus "mixer geometry") I get two parts. One part is a rotating cylinder with emptiness inside in the form of mixer. And the second part is square tank, that surrounds rotating frame.
Main options:
- steady state;
- two cell zones, one of them is rotating with speed 26 rpm;
- interface between rotating and stationary zone;
- realizable k-e model;
- no inlets and outlets, only wall no-slip boundaries
I have some doubts about my geometry model. I read some article, that says about simulating blades like zero thickness wall. But in my case it is impossible to enclosure zero thickness surface. How to simulate rotating frame in my case? Thank you in advance for any answer.
Natali is offline   Reply With Quote
cell zones, mixer, mixing tank, mrf, rotating frame
Mixing Tank Renuka Main CFD Forum 0 March 29, 2011 07:54
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
modeling spilling of water from a tank jemteo CFX 6 June 25, 2006 20:33
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 07:35
modeling bumping a tank Will Fitzgerald Main CFD Forum 1 January 5, 2000 18:15
