[TurboGrid] Wind turbine: problem with the hub radius
Old   March 12, 2015, 09:12
Default Wind turbine: problem with the hub radius
Gilberto Santo
MrDaimon is on a distinguished road
Hello everyone,
I am trying to create a mesh to analyze the flow around a wind turbine blade. The total span of the blade is more or less 48.5 m, thus I need a hub radius of approximately 1.5m (enough for having all the 3 blades mounted on the hub) and a shroud radius of 50 m. No matter what I try to do, I always get the following error while creating my geometry:
"The hub radius at the inlet of the blade passage is too small. Try moving the blade passage inlet closer to the blade."
Of course it doesn't make any difference where I move the inlet of my domain, as the hub is just a simple cylinder, with constant radius.
Did anyone experience a problem like this? Any idea about the causes of that? What can I do to solve it?
Thanks in advance
MrDaimon is offline   Reply With Quote
blade, hub, shroud, turbogrid, wind turbine
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 03:53
[ANSYS Meshing] wind turbine simulation meshing problem maxwell94 ANSYS Meshing & Geometry 0 January 26, 2014 14:06
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 11:50
Analyses and Design of Wind Turbine Blades, please help!!! heavymag Main CFD Forum 7 April 13, 2012 17:51
Pressure Drop/Porous Media within Shrouded Wind Turbine Simulation joshdsouza FLUENT 0 March 3, 2010 19:02
