[ICEM] Preparing Irregular Surface Boundary for Extrusion
Old   March 5, 2015, 07:59
Default Preparing Irregular Surface Boundary for Extrusion
J_Keel is on a distinguished road
Thanks for taking the time to read my post, I'd really appriciate any help which can be offered. I have several surfaces which are boundaries to my CFD domain that look like the attached image. I intend to extrude these surfaces outwards normal to the surface. As you can see there are some irregular cells on the surface and when extruded the shape of the channel becomes deformed. I have tried maually moving nodes to conform with the curve geometry but this only solves the problem ocassionally. Is there any setting/mesh repair process which can solve this and make the surface mesh flat, conforming to the surface curve geometry?
Thanks for your time and help.
J_Keel is offline   Reply With Quote
Old   March 5, 2015, 09:43
kad
kad will become famous soon enoughkad will become famous soon enough
I would suggest you to decrease the element size in general as you can see from picture 2 your geometry is not represented very well. The green surface is leaking out of the surface mesh in several places. Further you can define node spacing on the boundary curves (+refinement).
kad is offline   Reply With Quote
icem 15.0
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
