[ICEM] simulating a vertical axis wind turbine |
February 23, 2015, 07:19 |
mohsen razavi
Rep Power: 11 |
Hi everyone !
I am new to ICEM CFD. my thesis is about simulating a 3 bladed VAWT. but I have some general questions at the first of my job : 1- I have to do my job with 3 blades which are fixed on a circle with 120 degrees phase difference but i only have produced 1 blade in catia as you see in Image. I imported that blade to ICEM and I drew a circle . but i don't know how to duplicate (rotate) and transform my blade 120 and 240 degrees to produce 3 blades around circle. could you help me ? 2- I want my blades to rotate in the final model. how should i mesh so that my model could rotate in final simulating ? i mean i want a dynamic simulation. Thank you in advance |
simulating wind shear profile for a wind turbine--> How??? | mohammad | CFX | 14 | August 25, 2014 09:09 |
Vertical axis wind turbine - GGI problem | Piotr Zwolinski | CFX | 1 | January 12, 2014 06:01 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 04:38 |
Vertical axis wind turbine simulation | vincentwks | ANSYS | 0 | April 10, 2012 04:27 |
Vertical Axis Wind Turbine | courtjester140 | ANSYS | 2 | June 22, 2010 10:27 |
