[ICEM] 2D blocking of a multi-element airfoil |
February 17, 2015, 03:52 |
Anthony McCarthy
Rep Power: 12 |
Hi Guys,
My names is Anthony and i am currently studying for my undergraduate degree. I am trying to do analysis of airfoils using ICEM and FLUENT. I am trying to do a 2D analysis on a multi-element airfoil, and am having problems creating the blocking for such an airfoil? As in 3 separate elements with their own blocking. For a single element i have no problems. For this do i have to use the surface blocking instead? and if so can i then create blocks so i can define my boundary layer? This may seem like a very elementary problem as i am fairly new so all help is appreciated Thanks a lot Anthony |
February 17, 2015, 14:29 |
Sebastian Engel
Rep Power: 21 |
Hello Anthony,
i think you can create the blocking of the multielement airfoil the same way you did the previous airfoil (with a planar blocking). Except, your blocking will become more complex. with regards, Sebastian |
February 17, 2015, 14:35 |
Anthony McCarthy
Rep Power: 12 |
Hey Sebastian,
Thank you for the reply. O Okay as i was trying to do this but i kept and getting confused. Do you know what strategy you would undertake this by any chance as the current method i was using was to use a Ogrid what i would split and then collapse the vertices and associate this to the element. If i try this method with the 3 elements it gets very messy and i lose track on what i mean to do. Maybe i just need to keep practicing then? |
February 18, 2015, 10:47 |
Sebastian Engel
Rep Power: 21 |
Giving a general approach on how to mesh your geometry without having a look at it seems difficult. Moreover, I only have meshed a few airfoils (just simple ones) before myself.
To give you a few ideas how to design your mesh, have look at these pages: http://www.pointwise.com/theconnector/November-2012/Meshing-for-Aeroacoustics.shtml http://sandi.co.in/v2/home/projects/aerospace/nhlp2d/ http://sandi.co.in/v2/home/projects/aerospace/omar/ Following those examples, it seems to be a good idea to keep the c-grid structure. |
February 20, 2015, 09:25 |
Anthony McCarthy
Rep Power: 12 |
Thanks Sebastian for the links and help.
Unfortunately it seems a bit out of my depth for now so will not be continuing that element of the project. |
airfoil analysis, airfoil blocking, fluent 15, icem, icem 2d blocking |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 17:17 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) | mix | ANSYS Meshing & Geometry | 16 | January 17, 2016 14:41 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 10:48 |
[Other] 2D hex mesh on multi element airfoil | Verfblikje | OpenFOAM Meshing & Mesh Conversion | 0 | January 19, 2012 11:55 |
