[ICEM] How to even out this hexa blocking (clutch disc)?
Old   February 14, 2015, 10:48
Default How to even out this hexa blocking (clutch disc)?
Henke1896 is on a distinguished road
Hello everyone,
I tried to block the attached geometry which is very detailed and faced some problems which I could have avoided in advance but have not due to the fact that I am a complete beginner. Unfortunately I have very little time left for producing a valid result and the geometry is too complex to start again.
I am aware of the fact that there might be blocking-strategies that more efficient than the one I used
So my questions are:
- Is it possible to even out the mesh in any other way besides adjusting the number of parallel nodes per edge manually or change the blocking in a significant way? I have tried using global mesh params already but the result is not satisfying and I guess it will not by using part mesh setup too.
- Do you have an idea how to change the current or start a new blocking around the ultra-thin slit in the middle of the geometry and while avoiding the strong rise in mesh density due to shorter parallel edges?
- Will CFX solve a mesh which contains refined blocks 2:1?
Unfortunately I cannot upload the geometry or blocking files since they are to to big
I am sorry for any language problems.
Thanks in advance
Henke1896 is offline   Reply With Quote
Old   February 14, 2015, 10:52
Default Additional pictures
Here are some additional picture which may help.
complex geometry, evenly spaced, hexa, meshing 3d, refinement
[Workbench] Problem with hexa blocking in ICEM on a parametric study Jeremie84 ANSYS Meshing & Geometry 4 May 13, 2017 13:13
[ICEM] Hexa blocking a simple submarine siw ANSYS Meshing & Geometry 1 April 12, 2014 13:46
ICEM - hexa blocking msatrustegui ANSYS Meshing & Geometry 10 February 3, 2014 04:28
[ICEM] Hexa Prism layer NOT USING hexa (Blocking tab) la7low ANSYS Meshing & Geometry 5 January 29, 2012 00:50
[ICEM] Hexa blocking for cyclone Dr. Flow Squad ANSYS Meshing & Geometry 2 July 15, 2010 09:17
