February 3, 2015, 21:08 |
Overset mesh
Umberto
Rep Power: 12 |
Dear all,
I'm just wondering whether it is possible to build an overset grid with ICEM given that most of my research led to STAR-CCM+ which I have never used before. In case ICEM does not allow this approach is it possible to export the background mesh I have already created in ICEM to STAR-CCM+? |
June 9, 2015, 12:54 |
Oliver Westbrook-Netheton
Rep Power: 12 |
Hi cinclus,
It is possible to export meshes generated in ICEM to Star-CCM+. However with overset meshing you will have to be very careful that the boundary between the background mesh and overset mesh contain cells of approximately the same size. This could make generating efficient grids with inflation control in certain regions a problem if the overset were to move near them. Hope this helps. Ollie. |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 06:39 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
Overset mesh error | Caterpillar85 | STAR-CCM+ | 2 | February 12, 2013 06:54 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
