[Workbench] meshing pipe for two different diameter
Old   January 29, 2015, 18:23
Default meshing pipe for two different diameter
Tanjina Afrin
Tanjina is on a distinguished road
Hello Everyone,
Is there any way I can get structured mesh for the geometry of pipe with two different diameter using workbench meshing ? I am attaching my geometry here.
Thanks in advance.
REgards,
Tanjina
Tanjina is offline   Reply With Quote
Old   January 29, 2015, 18:28
Kapi is on a distinguished road
Hi Tanjina,
I reckon sizing option will help you get structured mesh in full geometry!
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   January 29, 2015, 18:50
Tanjina Afrin
How ? @ Kapi
I tried to something like this...but couldn't....
http://www.cfd-online.com/Forums/ans...ipe-ansys.html
Old   January 29, 2015, 18:57
Hi Tanjina,
That's a very useful link, what is the problem you are facing in using it?
Kapi
Old   January 29, 2015, 19:28
Tanjina Afrin
I am facing problem at this point.
"6) Select the 4 faces of one side as "source" and the 4 end faces as "target" (see Picture 3)"
For some weird reason, I can't select one of the face as "source" , so can't mesh. Since for my case it consists two different dia, that is another problem I guess.
Old   January 29, 2015, 21:35
Hi Tanjina,
when you are making geometry,
try to make two separate bodies and if they are not separated then create a slice between them.
go into mesh and right click mesh and see if the bodies are sweepable.
if they both are sweepable then you are good otherwise you have to fix geometry till it is sweepable.
now you right click and create body sizing for each body seperately such that both have similar mesh( you mite need to change element size depending upon your body)
Right click mesh and create method and choose "sweep" from it.
Hopefully this should do the trick for you.
Cheers
KAPI
[ICEM] Meshing pipe with different diameters Axlex ANSYS Meshing & Geometry 27 January 29, 2015 18:10
[Other] modelling & meshing of submerged pipe simonsg OpenFOAM Meshing & Mesh Conversion 0 October 24, 2014 11:31
[Workbench] Meshing for perforated pipe buried in porous zone Tanjina ANSYS Meshing & Geometry 0 September 24, 2014 10:41
[Other] separated pipe meshing tomokus OpenFOAM Meshing & Mesh Conversion 0 May 5, 2014 09:38
Spiral pipe modeling and meshing Adi FLUENT 0 August 1, 2008 01:39
