[ANSYS Meshing] Automatic parametric studies in Fluent
Old   January 29, 2015, 12:42
Question Automatic parametric studies in Fluent
dcavalie is on a distinguished road
I am just beginning to learn ICEM CFD for a very particular reason. I need to perform CFD analysis on multiple parametrically related geometries. I want to create a geometry, mesh it once (manually), import to Fluent, run analysis then have the geometry change automatically based on a parametric dimension table (hence having the mesh automatically regenerate), import, analyze, repeat... -Since I am completely new to the software I would like to find out if my goal is even possible before I dive in too deep. I do have Workbench if that is a necessary tool.
dcavalie is offline   Reply With Quote
Old   January 29, 2015, 18:21
Kapi is on a distinguished road
Hi dcavalie,
I am not sure how to do it in fluent.
The following link should help you get the idea how to do it tho.
http://www.edr.no/blogg/ansys_blogge...nch_cfx_remesh
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   January 30, 2015, 14:44
Question Workbench mesh vs. ICEM mesh
Thanks, Kapi. It seems that if I create my geometry from scratch from within Workbench I can then grid it there, too, and run a parametric study using Fluent from within Workbench. My question is: how does gridding in Workbench compare to gridding in ICEM? Are they even comparable? Does ICEM blow-away Workbench because it's a stand alone mesh generator?
Thx
dcavalie
Old   February 1, 2015, 18:11
Hi dcavalie,
I dont know much about ICEM, so I will leave it to experts to comment on your query.
Cheers
KAPI
Old   December 8, 2015, 12:22
Joakim
joxen is on a distinguished road
Thx
dcavalie
I've used Icem to perform an automate mesh during this fall. It's possible but hard if you have complex geometry, if possible divide your geometry in simple sub-domain, make an automate script for each one of them and then merge the mesh together in either ICEM (the file) or Fluent/CFX.
joxen is offline   Reply With Quote
ansys, fluent, icem, mesh, parametric
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 08:46
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
automatic case file loading in fluent calogero FLUENT 8 May 15, 2003 03:48
Parametric Studies Using Fluent 6.1 Jim FLUENT 0 April 12, 2003 11:22
