[ICEM] Blocking an elbow (block not conforming to geometry)
Old   January 22, 2015, 23:06
Default Blocking an elbow (block not conforming to geometry)
llrr12's Avatar
llrr12 is on a distinguished road
Hey guys,
I'm new to ICEM and I've done the tutorials in the manual. I'm trying to block a heliostat which has an elbow attached to a cylinder as it's support structure. However when I associated the edges of the elbow to the circular geometry at the ends the rest of the blocks aren't snapping to the elbow geometry. Can anyone give me any hints on how to do this association? Attached you can see that the edges at the ends of the elbow are already associated but the "bend" part still has its original block shape. This should be just like the tutorial except there are blocks around the elbow as well because there will be mesh there.
Just some further clarification to anyone that needs it. The vertical plate already has its block deleted, and I was planning to make an o-grid around the elbow/cylinder pylon for the mesh there. If any other info is needed please let me know.
Edit: Ok so I did a test myself. I found that if the surrounding blocks are deleted then the block around the bend will snap to the elbow geometry, if the blocks are there then it won't... How do I make it snap to the geometry without deleting the surrounding blocks?
Edit2: Never mind. Figured it out. If I just associate the edges to surface the mesh naturally conforms to geometry.
llrr12 is offline   Reply With Quote
[DesignModeler] Exact dimension of elbow geometry in tut Far ANSYS Meshing & Geometry 2 July 14, 2014 08:10
[ICEM] Merge created block resulting in not connected mesh imamwfgf ANSYS Meshing & Geometry 2 October 20, 2013 07:22
[ICEM] Assigning geometry to blocking siw ANSYS Meshing & Geometry 10 September 23, 2013 14:08
[ICEM] Cylinder Geometry and Blocking Leepox ANSYS Meshing & Geometry 2 November 21, 2011 11:32
block geometry inside fluid domain jeff Main CFD Forum 18 April 12, 2004 12:37
