[DesignModeler] Scripting suppression of Features in DesignModeler
Old   July 15, 2015, 23:26
Kapi is on a distinguished road
Hi Mizor,
Use boolean function to unite two bodies
var fBoolean = ag.gui.CreateBoolean();
fBoolean.Operation = 1;
Do named selection for target and tool bodies and select then like this
ag.listview.ActivateItem("Tool Bodies");
ag.bodyPick;
agb.AddSelect(agc.TypeBody, namedselection1);
ag.listview.ItemValue = "Apply";
ag.listview.ActivateItem("Target Bodies");
ag.bodyPick;
agb.AddSelect(agc.TypeBody, namedselection2);
ag.b.Regen();
Hope it helps
cheers
KAPI
Kapi is offline   Reply With Quote
Old   August 24, 2016, 07:49
Harry Eggo
harry94 is on a distinguished road
Encountered a problem with this. I'm trying to import lots of different curves so have scripted matlab to generate a script to be imported.
When I follow the format:
var NL1 = ag.gui.CreateCurve();
NL1.Name = "Name";
NL1.CoordinateFile = "FilePath";
agb.Regen();
var NL2 = ag.gui.CreateCurve();
NL2.Name = "Name";
NL2.CoordinateFile = "FilePath";
agb.Regen();
var NL3 = ag.gui.CreateCurve();
NL3.Name = "Name";
NL3.CoordinateFile = "FilePath";
agb.Regen();
I find that the first coordinate file is imported correctly but the rest are not. The error seems to be that Design Modeler is trying to do the following imports as point selections rather than coordinate files.
Is there any line of code I could use that would define the curve type as 'From Coordinate File'.
EDIT: Have no idea what happened but now Design Modeler is happy with my input and it's all working fine.
harry94 is offline   Reply With Quote
Old   October 1, 2018, 16:51
Default Body supression
  #23
John DeHart
Enginetix is on a distinguished road
Did anyone figure out how to properly suppress a body in design modeler? I'm reviewing the event handler script but the function format is not readily available.
Enginetix is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
[DesignModeler] Designmodeler java scripting Herbert2014 ANSYS Meshing & Geometry 13 October 16, 2019 17:19
Physical size of geometry in DesignModeler Michael Rasmussen CFX 9 June 16, 2017 04:27
[DesignModeler] find features of Gambit in DesignModeler code_source ANSYS Meshing & Geometry 13 April 30, 2014 08:33
[DesignModeler] change import by scripting dragonwei ANSYS Meshing & Geometry 0 September 17, 2012 06:08
