[ICEM] No volume meshing
Old   January 14, 2015, 14:11
Default No volume meshing
robboflea is on a distinguished road
Hi all,
I am trying to build a mesh for a turbine blade, including three separate volumes: solid, external fluid and cooling channels. All this using hexa meshing.
I started from a 2D blocking and then I extruded it in the radial direction.
The problem I am having is that ICEM seems to mesh only the surfaces but not the interior of the volumes. (the number of nodes is too low and I cannot visualize cut planes of the pre-mesh).
Anyone has any idea what the problem could be? Can it be due to the fact that I started with a 2d blocking?
Thanks a lot
Rob
robboflea is offline   Reply With Quote
Old   January 15, 2015, 07:33
Hi all,
I seem to have solved the problem. In case enyone will need it in the future.
I don't know why but the problem was that I was generating a pre-mesh without having the blocks displayed in the "blocking" section.
After displaying the blocks and refreshing the pre-mesh everything worked.
Hope it helps.
Rob
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 05:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
volume meshing nikita FLUENT 1 July 3, 2003 02:25
