[ANSYS Meshing] 2d Airfoil with Upper Surface Flap
Old   January 13, 2015, 17:35
Default 2d Airfoil with Upper Surface Flap
Eric
fuerst818 is on a distinguished road
Hello and thanks in advance for any help.
I have been working for a long time on properly meshing and analyzing a 2d airfoil with an upper surface flap. I am relatively new to CFD and am using ANSYS ICEM to generate my mesh and ANSYS Fluent to analyze.
I worked tutorials and followed a 3-part series on meshing a 2d airfoil on youtube. I was able to mesh the clean 2d airfoil and match the CFD results with experimental data I have relatively well.
However, meshing the airfoil with a flap has proven quite tough. I cant seem to block it properly in order to capture the BL of the airfoil along with the flap.
First Attempt
Second Attempt
I have also tried to use an unstructured grid but understand the a structured is often used more to capture the BL.
Thanks,
Eric
fuerst818 is offline   Reply With Quote
airfoil, flap, grid, mesh 2d, thin flap
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
airfoil mesh genaration and simulation with a trip on surface issue rajibroy Mesh Generation & Pre-Processing 1 December 3, 2014 03:04
Mesh of an airfoil with surface trip rajibroy Pointwise & Gridgen 2 November 13, 2014 12:23
Thin Flap on a Surface cwang5 OpenFOAM Pre-Processing 5 September 5, 2008 21:41
