[ICEM] Creating prisms layers for a geometry with sharp angles |
Eirik Løland Eide
Rep Power: 0 ![]() |
I'm quite fresh in meshing and a new user to this forum. I'm trying to add prism layers for a fin-tube geometry in order to capture the viscous sub-layer effects without use of wall functions. I successfully created the surface and volume mesh, using the Octree mesh method. setup.jpg closeup.jpg When trying to create prism layers I get surface orientation errors and multiple edges. Also, the mesh quality drops drastically. I've read on the forums that this is normal when adding prisms, but I would preferably have the minimum quality around 0,4. I suspect that the main problem is the sharp angles in between the fins when growing the prism layers. It is in these areas that I get the worst quality of the mesh and mesh errors. I've tried changing the prism meshing parameters without any luck. My question is then how to approach this problem. Is there a clever way to arrange the prisms in between the fins? Thanks in advance for any help. |
prism mesh |
creating geometry using "Script files" in ICEMCFD | jaber | Main CFD Forum | 1 | November 11, 2007 09:28 |
creating airfoil geometry using ICEM CFD | jaber | Main CFD Forum | 1 | November 2, 2007 16:26 |
creating a 2d plane from 3d geometry | casey | Main CFD Forum | 0 | April 18, 2005 14:11 |
creating geometry in CFX5.5 | adam | CFX | 5 | July 17, 2002 09:55 |
Frustrated creating your own geometry? | Brian Coon | Main CFD Forum | 0 | November 23, 1999 06:36 |
