[DesignModeler] How can i get log file of geometry from ansys workbench?
Old   January 12, 2015, 15:46
Default How can i get log file of geometry from ansys workbench?
Samet
eagle16 is on a distinguished road
Hello dear friends,
I will study a project for optimization and i will use an algorithm at batch mode.I want to know can i get all geometry codes from workbench like ansys classic(logfile).My study geometry is little complicated and so i want to create it at workbench cause it seems easier then ansys classic.If you could help me about that i will be very glad.Thanks for your support
eagle16 is offline   Reply With Quote
Old   January 13, 2015, 00:15
Kapi is on a distinguished road
Hi eagle16,
I am not sure if you can actually get the geometry codes from logfile.
I reckon you need to hard code it wrt X,Y and Z axis and use those coordinates to create line/curve.
You may use help section in design modeler to get idea how to do it.
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   September 11, 2016, 21:03
Si Cy
cyrusIII is on a distinguished road
Is there anyone here help with this question? I have the same problem. How is it possible to get the code from workbench and import it to APDL?
cyrusIII is offline   Reply With Quote
Old   September 11, 2016, 21:22
as mentioned above, you cant get codes of geometry thru DM.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 06:26
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
