[ICEM] creating a mesh with interfaces
Old   January 12, 2015, 14:23
Default creating a mesh with interfaces
SUBODH KHULLAR
sk692 is on a distinguished road
I want to study the flow field in a centrifugal pump. I am gonna generate a hex core mesh and use the MRF model in fluent to analyze the flow field.
My question is how do i generate mesh in icem so that i can specify the interface between the suction, impeller and the casing mesh as i am going to give rotational motion to the impeller mesh.
Should I mesh the whole pump at once or mesh each part separately and merge them (which is generating a bad quality mesh) ?
thanks in advance.
sk692 is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[blockMesh] Problems in creating a wedge type mesh Joscha OpenFOAM Meshing & Mesh Conversion 28 August 3, 2019 08:59
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[ANSYS Meshing] Strategy creating mesh 1 element thick owarlow ANSYS Meshing & Geometry 0 October 16, 2013 07:42
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
