[GAMBIT] Questions about 2D dynamic meshing
Old   January 7, 2015, 18:47
Question Questions about 2D dynamic meshing
Anonymous
turbo_agni is on a distinguished road
I am an undergrad student and am new to CFD softwares. I need to simulate a simple case in which there is a small oscilating solid block inside a rectangular domain (Please refer to the picture below). I am using GAMBIT 2.4 for geometry and meshing and FLUENT 6.3 for simulation.
I know that dynamic meshing needs to be done.
I have the following questions.
1) While meshing in GAMBIT, do I need to do something different for dynamic meshing or can I just use the standard Triangular mesh?
2) In FLUENT, do I need to specify both "rigid body" for the block and "deforming" for the interior or just one would do?
Thanks in advance
turbo_agni is offline   Reply With Quote
Old   January 8, 2015, 05:12
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you have 3 ways for dynamic mesh in Fluent (understand that remeshing will occure in Fluent, not in Gambit)
*Smoothing --> Cell Stretching (Tri)
*Remeshing --> local Remeshung (Tri)
*Layering --> add and suppress quad layers (Quad)
The BC will depend on the type of dynamic mesh you will choose
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 10, 2015, 01:05
Anonymous
I tried for a linear translation of a block in a rectangular domain.
1) I used a triangular mesh
2) I defined the following UDF
#include "udf.h"
DEFINE_CG_MOTION(Test_case, dt, vel, omega, time, dtime)
real ampl, w, pi;
/* reset velocities */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
/* define object movement law */
vel[0] = 0.08;
vel[1] = 0;
vel[2] = 0;
3) Compiled without error in fluent and defined the block as rigid body and default interior as deforming.
4) The block is moving but the mesh is not deforming or moving
HELP!!
Old   January 12, 2015, 03:32
-mAx-'s Avatar
Maxime Perelli
display and explain what you did and set.
Old   January 12, 2015, 07:28
acasas's Avatar
Antonio Casas
acasas is on a distinguished road
Don´t define the default interior as deforming. It should work.
Please, could you visit my threads and see if you could help me too?
http://www.cfd-online.com/Forums/ans...eed-valve.html
http://www.cfd-online.com/Forums/flu...g-useless.html
Thanks and good luck
acasas is offline   Reply With Quote
ansys meshing, deforming grid, dynamic mesh, gambit mesh
dynamic meshing 2D compression piston KITetima FLUENT 3 April 19, 2015 15:22
Error using dynamic meshing : 'Null cells detected' Jiang FLUENT 0 June 26, 2013 09:30
Dynamic meshing - UDF Jiang Fluent UDF and Scheme Programming 1 June 20, 2013 11:18
Dynamic Meshing with Flow 3D M_Agni FLOW-3D 1 June 13, 2010 19:20
Dynamic Meshing Max FLUENT 1 September 20, 2003 15:13
